water heater code
Old 09-07-09, 07:06 PM
B
water heater code
Hi..can can anyone help describe to me the nec code for wiring a 220 hot water heater in my new home? I have read a little about this and seem to think that I need a disconnect?? Any help will be thankful...
Old 09-07-09, 07:10 PM
R
You need a disconnect for the water heater...unless the breaker panel is within sight of the water heater.
Within sight meaning a person working on the water heater should be able to clearly see the breaker panel
Old 09-07-09, 07:13 PM
B
ok that sounds good..you could see the water heater from the breaker panel if the laundry door was open..lol...where should the disconnect be located? I have a 2005 nec code book.do you remember what section it is in? Thank you...
Old 09-07-09, 07:29 PM
R
it is in 422.30 and 422.31(B)
You can either install a 2pole 30 amp rated toggles switch or one of those 30 amp gray box disconnects like you would see on an a/c unit etc.
I would put it next to water heater and intercept the flex coming out of wall etc.
