Split circuit
Received 0 Votes
Split circuit
Question regarding a split circuit. Was checking a duplex to day and it had two neutrals wired together and two hots wired together. Then I seen there are two breakers on the circuit. I was was surprised being wired this way the breakers did not trip. Is this because both hot leads were on the same bank? Thanks
Received 0 Votes
There is no outlet ... just the wires connected together by a wire nut... two hot, two neutral. The outlet has been unused since 1964. We are remodeling the church kitchen, and it is located under the sink. Was intended for a disposal I would imagine. I thought the one hot was a feed and the other was a traveler. To kill the circuit it took two breakers. to do so. Impossible to me, but it did..
Received 0 Votes
I don't understand???? You say you were checking a duplex.....but then in your last post said there is no receptacle??
I know you want to help your church but doing electrical in anything but your own residence is leaving you wide open for liability claims. I strongly urge you to consider a monetary donation to help hire a licensed electrician for any work in the church.
