100A main to 50A sub
Old 09-26-09, 07:49 PM
My house is 3000SQFT with basement(finished).I would like to rent that basement but have no receptical for stove,fridge and microwave. Main panel is 100A and no more slots for breakers, my concern is can I add 50A subpanel, addin on sub,one DP 40A breaker for stove,wire will be 15 ` long from panel to recepticle, four 15 A brkrs , fridge,microwave, and two that i will take out from main panel, and replace for 50A.
Would that be enough if both stoves run at the same time,or maybe in summer stoves and AC
Old 09-26-09, 08:56 PM
I am concerned that a 100A panel is not sufficient for a 3000 sq ft home, let alone another apartment with full kitchen within. I recommend a "demand load calculation" to determine if the service size is adequate. A service upgrade to a 200A, 40 space panel may be appropriate.
Old 09-26-09, 09:08 PM
ray2047's Avatar
If you have gas I would strongly suggest gas for the range. That would significantly ease your electrical requirements. Also make it a part of the lease only gas dryers are permitted or just provide the dryer. Water heater should be gas also.
Old 09-27-09, 05:13 AM
How can I calculate dmand factor,
Thank you for your answers
Old 09-27-09, 08:50 AM
ray2047's Avatar
Google is your friend and sometimes quicker.
- Google Search
Old 09-27-09, 11:16 AM
If you going to convert the basement into apartment I really strongly sugget that you will have to change the plan somehow what you will need seperated panel and meter for it {unless you include the electric in the rent }
Merci,Marc
