Three-way switch connections
Old 09-29-09, 08:30 AM
Angry Three-way switch connections
I moved my three-way switches at the top and bottom of the stairs and am confused on how to wire them up again. The power comes into switch one and feeds the light and switch 2. The confusion is with switch 1, how do I wire that one up, I know I should have diagramed it out prior to disconnecting and moving them, because I would not have the probelem now
Old 09-29-09, 09:20 AM
pcboss's Avatar
Received 114 Votes on 99 Posts
Does sw2 only have the 3 wire cable in the box?
Old 09-29-09, 10:05 AM
Yes sw2 has only the 3 wires
Old 09-29-09, 10:54 AM
pcboss's Avatar
Power in black to re-marked white in cable going to sw2. Re-marked white to COMMON on sw2. Blk and red in 3 wire cable to brass screw at sw1 and sw2. Black from fixture to COMMON at sw1. White from light and incoming white joined together.
Connect all grounds together and to all switches.
Old 09-29-09, 11:26 AM
I will give that a try, thanks
