SPDT Center Off Switches???
Old 09-29-09, 07:58 PM
I have an old Rencom Relay system in a house. I am having problems finding SPDT Center off switches. I know TouchPlate has some, but the only problem is I have an older Rencom Relay and also a new Rencom Relay (Duplex House) being used, so they have different Common's. Does anyone know where I can purchase these switches from? Please let me know. Thank you.
Old 09-29-09, 09:27 PM
Received 2 Votes on 2 Posts
Don't know if this helps. but radio shack has SPDT center off toggle switches for about $3.50.
I think they handle up to 10 amps at 120V.
Old 09-30-09, 03:09 AM
Search Leviton 5685.
I don't understand, though. An SPDT switch has one common that switches between two terminals. If the relays use different commons and you want to use the same switch, you'd have to use a DPDT. In that case the Leviton model is 5686.
Old 09-30-09, 05:26 AM
I'm sorry, I mean on a standard light switch there is TWO SPDT Center off switches.
Old 09-30-09, 08:39 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
What? A standard light switch is SPST. Do you mean a standard switch for your system?
Old 09-30-09, 05:16 PM
are you refering to the old dispard switch if so that will be little tricky to find it.
something like this ??
If so let us know we may know couple place may still sell it.
Merci,Marc
Old 09-30-09, 05:25 PM
Not sure if a "dispard" switch is what i'm looking for.
I am looking for a 2 switch, SPDT center off wall switch that fits a standard wall switch mount.
Looks like this, but the one below only has 1 common. I need 2 common's.
ECL-4B-0L - $26.00 : Touchplate Lighting Control, On-line Store
