Splitting up my switch
Old 10-02-09, 11:31 AM
Hello everyone, I'm new to the forum but have been anonymously browsing for awhile. What a great resource!!
So I have a question about the light switch in my bathroom that is also hooked up to the fan/vent. I was wondering how to separate them and put in a new switch for the fan so they both run independently (I don't need the fan running every time I go to the bathroom).
can anyone point me in the right direction or tell me how to go about this?
Thanks!
Old 10-02-09, 11:36 AM
Received 42 Votes on 40 Posts
What wires are available at the switch? Are the light and fan the same device or separate?
Old 10-02-09, 11:38 AM
Gunguy45's Avatar
Super Moderator
No pro...but you'll need to know what wires are available at the fan and the switch. You may not have enough wires for 2 seperate switches. If you don't mind pulling new wire, then its not really that big a deal. You can get switches that have 2 levers stacked vertically and will normally fit in a single box.
The problem may be if the box is already small, you may have to replace the box if you put more wires in it. Thats the way advise works here...either do it right or not at all.
Old 10-02-09, 11:49 AM
Thanks guys, and that's why i'm here. good stuff. I hope to get into the box tonight to see what's going on. i wanted to get the question out because i was annoyed this morning with the fan...it was just one of those mornings....a cold one at that.
I guess i was hoping there'd be some way to intercept the fan and the light switch with another switch.
I will post this evening with my findings...unless my initial plan is possible?
Old 10-02-09, 11:55 AM
pcboss's Avatar
Received 23 Votes on 19 Posts
In the worst case you would be looking at running a 3 wire + ground cable between the switch box and the fan.
Old 10-02-09, 12:02 PM
And the best case scenario?
Old 10-02-09, 12:50 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
You'd already have one. If you have only a 2-conductor cable between fan and switch it will need to be replaced. If it is conduit, unlikely, you will need to pull a third wire.
