Furnace not warming up
Old 10-07-09, 06:28 AM
H
Hi,
I recently bought a house, and have never used the Furnace. I changed some of the panel switches to GFCI because they did not have proper ground.
Now my furnace does come on, but it does not heat properly and it is signaling the following:
"115 volt AC power reversed, poor grounding or system
voltage too low"
Any suggestions?
Thanks
Old 10-07-09, 06:56 AM
B
I would check the wiring to the furnace using a multimeter and the installation instructions for the furnace. I would be sure the power supplied to the furnace was per the installation instructions for the furnace.
I would check that hot went to hot, neutral to neutral, and ground to ground. And that the wire/outlet for the furnace was wired properly. Also that there was a good proper electrical system ground.
If you don't know how to do this, best to call an electrician.
If you want to learn. Get books on basic home wiring at home improvement stores and read them cover to cover.
And here is more...
Mains electricity - Wikipedia, the free encyclopedia
Also there are jumpers/setting in some new furnaces for the type of voltage supplied. Check the installation instructions that these are set properly.
(If all else fails, read the directions!)
Old 10-07-09, 11:49 AM
R
Originally Posted by harpy2010 View Post
Hi,
voltage too low"
Any suggestions?
Thanks
How did you wire up the GFCI breaker. Where did the white & black wire go on your breaker.
Jim
Old 10-07-09, 07:05 PM
R
Received 1 Vote on 1 Post
Can you elaborate on this? Are you talking about circuit breakers in the service panel or wall plate GFCI's?
Electric heat? Forced-air? Boiler?
If the furnace worked before you changed something and it doesn't work now, find that circuit and change it back to the way it was. At least you'll have heat until you figure out the cause.
