Shocking pipes and water
Old 10-10-09, 10:48 AM
I recently had to replace a bad water heater in a small apartment that I have over a barn. While replacing it I noticed, even with the old water heater removed, that the ground wire and the water pipe going to the heater would shock me if I grabbed them. I went ahead and installed the new water heater.
This morning my son was using the water spicket on the outside of the barn and he said he was also shocked.
How can I diagnose and fix this problem? I'll be watching this thread closely so if anybody needs more information or needs me to test something just let me know.
Thanks in advance,
Torch
Old 10-10-09, 11:15 AM
F
Before you do anything more with waterheater first do you have subpanel there ?
If so read on
You need to check the netrual and ground connection at subpanel and main panel to make sure they are not corroded or loose this is very important step here you can not ingore this one.
Do this subpanel have three conductor set up or four conductor set up?
That will make the diffrence on troubleshooting.
Do the lights stay bright or dim when you turn on pretty good load like portable heater if get dim or brighter then you loose netural connection if stay the same you will have to dig in deeper to trouble shooting this system.
Check the ground rod if you have it there.
Get the voltmeter and have one probe touch the water pipe and the second probe touching the ground you should read very low or zero voltage but if more than that please follow this one
turn off the waterheater breaker if that go away if not then turn off other breaker or remove the fuse one at time until that go away then you will need to check that circuit very carefully.
Merci,Marc
Old 10-10-09, 11:53 AM
Marc,
Thanks for responding. I read 120 volts at the water pipe with the voltmeter. I've made some troubleshooting progress since my original post. First, I was able to isolate the problem to a single circuit and then even to a single light switch. When the lights were turned on, the pipes were 'hot'. When they were off they were not hot. I'm still confused how the pipes, which do not come in close proximity to the lights which are causing the problem, come together. Is the power leak into the ground going back through the panel and into the pipes somehow?
Thanks
Old 10-10-09, 12:28 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Are the lights grounded? If so any chance the neutral is intentionally or unintentionally connected to the ground. Are you sure neutral and hot are not reversed?
Have you measured between the pipes and a long screwdriver stuck in the ground?
Old 10-10-09, 02:23 PM
Ray,
Thanks for the reply. I have 9 fluorescent fixtures on this switch and haven't checked their ground yet.
When you ask whether there is any chance that the neutral and ground are connected I'm not sure what you mean. Do you mean at each fixture, at the switch, or in the breaker box? Or do you mean all of the above?
I'm also not sure what I'm supposed to do with the screwdriver.
Old 10-10-09, 03:12 PM
ray2047's Avatar
All of the above. Sometimes when a ground wire isn't present some one will make a bootleg ground by tying the ground to neutral but it can happen accidentally also.
Lets skip that for now. On further though my reasoning may have been wrong on that.
Old 10-10-09, 05:14 PM
F
Originally Posted by MaterDei View Post
Marc,
Thanks
Ok now that really help here a bit to pinpoint here what you have to do is check each luminaire to make sure the cable is not pintched or have a screw hit a conductor.
You can do this by elemated one luminarie { disconnect } a time if that voltage on the pipe go away then you have something affect it you will need to dig more deeper on that spot to see why it cause it.
I know it will take time but one out of nine can go pretty fast once you know how this luminaire circuit lay out and also check the switch box as well to make sure nothing is out of the line.
Merci,Marc
