Conduit bends and other rules
Old 10-11-09, 08:48 AM
Are there any rules I need to know before installing wiring in PVC conduit (interior)?
Can I use the short 90 degree bends at corners? Are the big loop bends just to make pulling easier?
Is there a rule for when I switch from cable to wire in conduit? Electrical box for the splice?
Anything else I need to know?
Is PVC the easiest type to work with?
Old 10-11-09, 09:14 AM
grey vs white pvc
you can only use the grey pvc conduit with the sweeps for the 90s
the grey schedule 40 is for electrical
white pvc is for irrigation
you can use LBs for outside 90s since you can pull through a LB 90, but as long as you do not bury it in wall where you have no access to the LB,
and you can use a j box ( if outside make sure it's a "bell box" or a junction box rated for outdoor exposure ) in the run from transitions
yes the 90's are for making pulling easier ( no more than 4 - 90s in a run before you must put a junction box )
i'll take it you do not have a EMT bender, as EMT is almost as easy to run a pvc
is this in a exposed location like a garage?
Old 10-11-09, 10:34 AM
I looked up the right terms and it's a 90 degree elbow I meant. Are you saying I have to use sweeps at bends? Is there a reason I can't use a 90 degree elbow when it works better? I'm thinking about when I have to go thru a wall.
When I go through a wall (to an exterior light fixture or outlet) do I switch to wire using an electr box on the interior of the the wall? Does the conduit have to go all the way through to the light or outlet box? How do you do this?
Yes it's exposed on interior garage walls.
Old 10-11-09, 10:52 AM
F
Received 35 Votes on 27 Posts
Yes.
No.
The fittings MUST have the proper radius to allow pulling the wires through with minimal friction. Using plumbing fittings will damage the wire's insulation if it is even possible to pull the wire through the fitting. Conduit MUST be continuous from beginning to end.
Old 10-11-09, 11:16 AM
Gunguy45's Avatar
Super Moderator
Received 3 Votes on 3 Posts
hey furd...did a pic not make it in your post? Maybe the ones showing plumbing 90's?
Thought the LB (?) was ok.....
I'm confused....
Old 10-11-09, 11:52 AM
F
It's all there when I look, the word Yes, a 90 degree conduit bend, a 45 degree conduit bend, an LB fitting then the word No and then a 45 degree plumbing elbow and finally a 90 degree plumbing elbow.
Old 10-11-09, 11:53 AM
Gunguy45's Avatar
Super Moderator
Ahhh ok...it is now...it wasn't for me right after you posted.
I guess I'm not as confused as I thought....lol
Old 10-11-09, 01:38 PM
chandler's Avatar
Received 5 Votes on 5 Posts
Just more fuel....I'd rather bend EMT than mess with all those sweeps, etc. Just easier.
Old 10-11-09, 05:33 PM
Crystal clear, thanks, and illustrated too. I've always wondered why no 90 degr elbow in gray PVC.
On going thru the wall from the interior to an exterior outlet or light fixture, if I understand you right I need an LB fitting to turn into the hole in the drywall, then I need a short section of conduit to span the wall space between the LB and the fixture box or outlet, right?
Old 10-11-09, 11:18 PM
F
Yes, you are correct. Also remember that an LB (and all other such fittings) cannot be "buried" inside a wall but must be left accessible.
