Max load rating on appliance circuit
Hi all,
I'm trying to balance out my kitchen circuits and I have a few items left to find homes for.
Here are the items and their max draws:
Built in microwave: 13A (plug)
Built in coffee maker: 11.7A
Vent Hood: 3.8A
Warming Drawer: 3.75A (plug)
Stove sparker: 0.7A (plug)
Originally, I was going to group the MW/WD together and the Hood/stove/coffee, but that ends up with 16.75A and 16.2A total on each, respectively. This is above the 80%, but I'm not sure if that applies here. In this case, I can see them all being used simultaneously.
I'm running out of room on the panel, so I'd like to save a circuit if at all possible. Worst case, I can move the stove sparker to my basement lighting circuit (where it was before).
Any ideas? Am I right about the 80% being the max capacity on ANY circuit?
Thanks,
Anthony
Vent Hood: 3.8A
Thanks,
Anthony
Personal experience - don't put anything else on the microwave circuit.
I know you're running out of room in the panel but I'd use three circuits here if that coffee maker sees anything more than occasional use.
These each need dedicated circuits because they are built-ins. For a "fastened in place" appliance, it requires a dedicated circuit if the appliance will draw more than 50% of the branch circuit capacity. Both exceed 50% of a 20A circuit.
These could be powered by a general-purpose lighting or receptacle circuit, but not one that powers kitchen, dining or pantry receptacles. Either would be okay to share with a dishwasher or disposal if you happen to have those available.
This can be powered by one of the small-appliance branch circuits that feeds kitchen countertop receptacles or any general-purpose circuit.
Vent Hood: 3.8A
Thanks.
I may just bite the bullet and do a new subpanel. I have to make a junction box for the upstairs lighting circuits next to the main panel anyway, so it won't be too much hassle to just go with a new panel. It will let me clean up the existing (full) panel too.
Question about subpanel: since they will be right next to one-another, can I just have a breaker in the main panel and use a main-lug style subpanel? Or is code now such that both sides need a disconnect even if they are in close proximity?
This is what I'm considering:
Shop Eaton Cutler-Hammer 12-Circuit 12-Space 125-Amp Main Lug Load Center at Lowes.com
The subpanel does not need a main breaker as long as it is in the same building as the panel feeding it. A main breaker is only required when the subpanel is in a separate building.
That's what I thought, but I'm not always up on code changes. I'll read up and do some shopping online tonight. I'm sure I'll be back with some questions.
Thanks all.
Thanks all.
Wire size for the feeder
Just a check-my-math question:
6/3 NMB okay for a 60 amp breaker feeding the sub panel? I imagine it is not going to be more than 15' of cable total. Obviously totally indoors, just stapled down to a joist or two overhead.
Thanks.
Thanks.
That is pretty much what I think should be done with kitchens these days. So many things which use a lot of amperage. Deep fryer, hot plate, coffee maker, waffle iron, or anything which heats.
When I redo my kitchen, I think I will have double outlets (4 total) at each countertop location and each on its own 20 amp breaker!
The real test is during a holiday like Thanksgiving when you have everything going at the same time...
There's a little bit of distance between them to accommodate the 2nd floor lighting circuits. They were in a demo'd soffit and I had to reroute. The long route in the stud bay will leave me about 3' short to the main panel.
I figured 5' apart, 3' of slack in the main panel and 2' of slack in the new panel + extra to go up and over.
Thanks for the confirmation on the 6-3. I'll try and get these parts ordered this weekend.
