Doorbell transformer size
Old 10-13-09, 06:01 AM
Received 1 Vote on 1 Post
Hi everyone. I tried using the search to find the answer to this, but lately all it says is "Database error". Sorry if this has already been asked.
I've got two ding-dong type door bell chimes in my house and I think I need a larger transformer because one of the chimes works, but very weakly (I don't hear the "ding", but I do hear the "dong"). I tested the weak chime using a 12V DC power supply and it worked very well. If it matters, the doorbell button is also lighted.
One of the chimes is a brand new Heath Zenith and wants either a 16V 10W or a 16V 15W transformer. The other chime is very, very old and is unmarked.
Do you know what size doorbell transformer I should buy in this application? Should I look for a 30W transformer?
Thanks,
- Joe
Old 10-13-09, 06:13 AM
G
Received 2 Votes on 2 Posts
For multiple chimes, a 16 volt transformer at 20 - 30 VA is recommended. Personally, I would go with the 30 VA. Should be available at your local big box store.
Old 10-13-09, 06:14 AM
Great! Thanks for the quick reply!
- Joe
Old 10-13-09, 06:27 AM
A
Concur, although I couldn't find a 30VA at the big box six or seven years ago when I installed mine.
My 30VA runs 3 ding-dong chimes and two buttons with incandescent bulbs. Works fine.
Also, make sure your wire is rated for the current. I fixed a "stuck" doorbell for somebody else; the chime coil insulation melted and shorted, then the in-wall wiring cooked before shorting and burning out the transformer. Lucky.
At my house I used 16 AWG but 18AWG is probably fine. I mention this because in some newer homes the installers have used 22 or 24 AWG twisted pair wire.
Old 10-13-09, 06:35 AM
I just checked the cable and it is unmarked. The individual wires are pretty thick though - maybe 16 or 18 awg. Definitely thicker than UTP cable. I don't think UTP was around when this house was built (1965)
I did a quick search and the largest that most stores seem to carry is 20 watt, but I've been burned in the past by relying on their websites to tell me what a store carries. Guess it is time to take a field trip.
Thanks again - you guys are great!
- Joe
Old 10-13-09, 08:38 AM
A
I have an Edwards 598. It's got triple secondary taps for 8, 16, and 24 VAC. I am using 16 VAC at 30 VA. I got it locally at Graybar, I think.
Elliott Electric - Search Locations
Old 10-13-09, 12:45 PM
Well, I installed the 15w transformer. The second chime now does a "ding-dong" but the "ding" is not quite as strong as the other chime (probably because the second chime is 40 ft away from the transformer. I think I can live with it though.
Thanks!
- Joe
