AFCI trips when switching lights off???
Old 10-19-09, 11:30 AM
Hey Folks,
I recently had my whole house rewired, a 200 amp panel upgrade, and added recessed lights.
The bedrooms feature AFCI breakers. One of the AFCI breakers has tripped 3 times in the last month.
The last time it tripped was when I turned a switch off???
I did a quick load calc, and everything is fine.
what could be causing this?
Old 10-19-09, 11:57 AM
I
Received 42 Votes on 40 Posts
Switches make a small spark when they switch on or off. AFCI breakers are designed to trip when they detect sparks. Normally the spark made by a switch is too small to trip the breaker, but sometimes it happens.
I would first try replacing the switch with a new one in case the contacts are worn on the old switch. Next I would try replacing the AFCI breaker with a different one.
