Sharing ground between two FMC between the same 2 boxes
Old 10-20-09, 11:08 AM
Here's my situation:
I ran a few circuits in a 1/2" FMC and also ran a 3/8" FMC alongside it for a couple more. I have the 1/2" filled to near the max (enough that another wire will go above 40% fill). I had planned to run one circuit with a ground wire through the 3/8" FMC but now realize I need another two neutrals for two circuits in the other cable (I didn't know AFCI's couldnt share neutrals). The new wire wont overfill the 3/8" FMC, but I think it'll be too tight to get a 12 ga ground wire in there easily.
Here's the question:
Is it acceptable to use the ground wire (12 ga - same size as largest conductor) that's running through the 1/2" FMC since both runs of FMC are terminated to the same boxes at each end?
I'm hoping the answer is "yes" because it'll save me a lot of trouble, but I want to verify before moving ahead.
Old 10-20-09, 11:53 AM
I
Received 44 Votes on 42 Posts
No it is not acceptable. All conductors (hot, neut, gnd) of any given circuit must go through the same conduit.
Old 10-20-09, 01:09 PM
Sucks for me, but not surprising.
Thanks
