sub panel question
Old 10-28-09, 08:56 PM
sub panel question
Ive read the sticky at the top of the page.
I have a 200 Amp in the garage and I was going to add a smaller sub right next to it.
3 wire feeding the house.
the neutral and ground are connected.
I was going to remove the 220 plug (bottom left) connected to the bottom left of the circuit panel and run the wires to the new sub panel.
So I was going to put in a 100 Amp breaker and 125 Amp sub panel.
Should I treat this like a 4 wire (even though the current 220 recepticle shown is a 3 wire) 220v appliance and run
Hots to Hots, neutral to neutral, and ground to ground.
In the main, the Neutral and ground are together?
Old 10-28-09, 09:04 PM
Niadh's Avatar
Run 4 wires to the sub and keep the sub's neutral and ground bars separate. The main panel is the only place the neutral and ground can be bonded.
Old 10-29-09, 04:28 PM
simple enough. ground and neutral will come back together at the main. In the sub, they will be isolated.
thanks.
