Faceless GFCI for Whirlpool tub location
Old 11-09-09, 09:29 PM
So as I am planning my whirlpool tub install and the GFCI outlet under the apron that was installed looks like it might interfere with the tub. I need to reposition the outlet and since I am redoing it make it a single. I was searching for ideas and ran across a faceless GFCI device that would go inline with an regular outlet (non GFCI). The question is how far (or close) must this device be from the tub and should it be at switch height?
Thxs
Old 11-10-09, 05:45 AM
pcboss's Avatar
Received 39 Votes on 34 Posts
I would mount it the same as the switches just for a consistant look. Pick a convenient location outside of the footprint of the tub.
Old 11-10-09, 07:03 AM
chandler's Avatar
Received 3 Votes on 3 Posts
Agree, I like mounting them just outside, like a receptacle, and run the wires on to the receptacle for the tub, which is under the apron. Should you have a trip, it would be obvious and can be easily reset. Or in the switch combo, either way.
