GFCI Breaker/GFCI receptacles
Old 11-10-09, 09:46 AM
our 2 1/2 baths share the same line for the receptlacle outlets. The line has a GFCI breaker in the service panal. When we bought the house the inspector said it needed GFCI outlets at all of the outlets in the bathrooms. Is there a problem with changing the receptacles to GFCI?
Old 11-10-09, 10:18 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
More proof a few housing inspectors never even audited the class Electric 101. You do not need GFCI outlets. you need GFCI protected outlets (receptacles). Adding GFCI receptacles isn't necessary. In rare cases having two GFCIs can even cause problems.
Old 11-10-09, 10:29 AM
Ray,
Thanks for the help
Old 11-10-09, 12:34 PM
R
Ray, good answer. The thing he has to do to make it right for this inspector is to label the receptables in the bath GFCI protected. Then he should be in code as long as that circuit is on a GFCI breaker.
Thanks!
Jim
Old 11-10-09, 03:29 PM
pcboss's Avatar
Received 114 Votes on 99 Posts
Well said Ray, shame that some are so ill-informed.
