220v to 110 Elec. to Gas stove
Old 11-11-09, 04:40 AM
Have three wire 3 prong plug 30A for stove. Can I use the wire
to get 110v plug by changing circuit breaker in panel to a 15A single pole?
Old 11-11-09, 05:21 AM
rjfg007: yes you can use the line for120v (2 wires and ground)
Old 11-11-09, 06:03 AM
chandler's Avatar
Received 3 Votes on 3 Posts
No you can't use the 240 volt set up for 120 volts. You don't have a neutral. Don't use the ground as a neutral. Use the black wire for connecting to the CB, relocate the white to the neutral buss bar. Using that size wire is overkill, and I am not sure you will be able to find a receptacle to take that size wire, but if you can, it will work.
Old 11-11-09, 08:24 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
The key is 3 wire. If you do not have a bare or green wire or metal conduit all the way back to the panel you can't do this. Code does not permit the remarking of wires #6 or smaller in this case.
Old 11-11-09, 03:40 PM
chandler's Avatar
Ray, I was thinking since it was a 30 amp circuit it was probably only 10 AWG. Sort of small for a stove, but that's what they said. I was also assuming they used romex, which he could switch around.
Old 11-11-09, 06:22 PM
ray2047's Avatar
Yes. We just read the same thing differently. I just didn't believe #10 was correct and I was visualizing old cloth ungrounded 3 conductor NM. If it is 10-2 NM-b/g then I'd suggest a 20a breaker instead of 15a the poster proposed so the wire will fit without a pigtail and using a commercial side clamp type receptacle to make connecting easier.
