Low Volt Light wiring in wall
In wiring in cabinet lighting, I intend to run wiring in the wall.
I am aware that this needs to be NM, but I am unsure of what housing or box is required to join this back into the Low Volt wire attached to the lights.
(This is to pass a section without cabinets)
Thanks,
Justin
Thanks,
Justin
Low voltage wiring has far less restrictions then wiring over 50 volts. Splices are not required to be in a box. The cable you use does not need to be NM-B but does need to be a rated cable type for the location you are running the cable.
