electric drill started shooting sparks now dosn't work
Old 11-21-09, 05:05 PM
I have a Miluakee Hole Hawg I was using today when suddenly abnormally large sparks started shooting inside the dust vent. The drill stopped working. I pulled the trigger maybe 5 more times. Sometimes it would shoot huge sparks, kinda run and sometimes nothing would happen. I was drilling holes for electrical with a 1 inch auger bit. The Hole Hawg has a rather low amount of use compared to what these should be able to handle. Any ideas what the problem might be and/or where to start looking? Thanks for any help.
Old 11-21-09, 05:20 PM
chandler's Avatar
Received 6 Votes on 6 Posts
Yeah, unscrew the brush holders and pull them out. I feel you will find they are toast. You can buy new ones and provided you haven't boogered the innards, you will be fine with new ones.
Old 11-22-09, 10:28 PM
The brushes didn't look toasted, but I did think I saw something in there. I stuck a hook in there and pulled out a small dust/hair ball the was lodged behing one of the brushes. I could clearly see how this would cause arcing. I cleaned and put it back in. Now there are very very small, pretty constant, blue sparks constantly under both brushes, I think this is normal though...?
Old 11-22-09, 11:24 PM
F
A very small consast bleu sparks from the brushes is normal as long the commuaitors are not damaged you are fine with that part.
Merci.
Marc
Old 11-23-09, 07:51 AM
Excellent, thank you all for your help. I was really upset with Milwuakee when I thought I cooked my drill.
Old 11-23-09, 09:52 AM
I
Received 43 Votes on 41 Posts
That is a really nice drill -- would be a shame if it was toasted.
