What is the most common Plug type for in Hotel room A/C?
Old 12-08-09, 01:13 PM
A
What is the most common Plug type for in Hotel room A/C in the USA and in the Middle East?
There are four types and I would like to know which one of them is the correct one:
1. 120V 15amp
2. 120V 20amp
3. 240V 15amp
4. 240V 20amp
Your help will be really apprechiated so much.
Thank you.
Old 12-08-09, 01:19 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Old 12-08-09, 01:22 PM
ray2047's Avatar
Post deleted. Double post
Old 12-08-09, 01:33 PM
A
Originally Posted by ray2047 View Post
Thank you so much for your reply. I am doing it for my boss. What I would like to know is which one of them is the most common one? I don't need detailed information about the plugs I just want to know the most used one in the USA and the Middle East?
Thank you so much again.
Old 12-08-09, 01:52 PM
I
Received 43 Votes on 41 Posts
They are all pretty common in the USA, so is 240V 30A. I have no idea about the middle east -- it probably depends a lot on the specific country. UAE is a heck of a lot different place than Iran for example.
Old 12-08-09, 02:15 PM
HotxxxxxxxOKC's Avatar
Hopefully a qualified electrician is doing this work, specially in a hotel.....
Old 12-08-09, 03:39 PM
The type pf plug needed would depend on the size and voltage and amp level of the AC unit itself.Start with the AC and use the appropriate receptacle.
If this is a job where the idea is to set up the rooms for future ACs you'd need to ask the general contractor or hotel management what type and size etc ACs they were planning on installing.
Old 12-08-09, 06:08 PM
F
The size of the plug will depending on the size of A/C plus electric heat if have there also heat pump verison however if you have 277 volts or three phase supply the in wall A/C unit are hardwired in USA side.
The European verison kinda toss up depending on which country you live so there is about half dozen verison.
Merci,Marc
Old 12-09-09, 05:57 PM
C
In hotels I stayed at in recent years (middle range chain hotels mostly), they use a mostly standard heater-A/C which uses a NEMA 6-30 plug.
