ground to neutral?
Old 12-12-09, 06:12 PM
P
ground to neutral?
if someone spliced a ground wire into a neutral (behind the walls), how could I tell? This is a two wire home 1954, but one socket has three wires black to hot, white to neutral, and a red to socket box.
Old 12-12-09, 06:52 PM
B
You should be able to disconnect the neutral wire for that circuit at the breaker panel, then measure an open circuit from the ground to neutral on that circuit.
Everything on that circuit would need to be unplugged though for the test to be valid.
Continuity testing...
Testing fuses Page
Old 12-12-09, 07:51 PM
P
thanks. (message too short, it must be at least 25 characters)
Old 12-12-09, 09:05 PM
P
How do I tell which neutral at the box is for that circuit?
Old 12-12-09, 10:14 PM
B
Turn off the circuit breaker for that circuit.
Then you can follow the black wire going to that circuit breaker back to the cable it came from.
And that same cable would also have a white wire. Follow that white wire to where it goes and disconnect it.
Old 12-12-09, 10:40 PM
P
thanks again. (message too short, it must be at least 25 characters)
