grounding a switch in a metal box
Old 12-14-09, 09:03 AM
I have a light switch in a metal jbox. There is no grd wire connected directly to the switch (green screw). The box is grounded (I see the other grds wound together and 1 grd wire screwed into the metal box. Should I ground the switch with its own wire and pitail int othe others or is it grounded as it is screwed into the metal box with a metal screw? It goes to an outside light.
Old 12-14-09, 09:14 AM
pcboss's Avatar
Received 87 Votes on 74 Posts
Yes, add a pigtail and connect it to both the switch and the other ground wires in toe box.
Old 12-14-09, 09:21 AM
Any guess at to why they would'nt have done it?
There were also a couple other 3 way switches in the house that are NOT in metal boxes that already went ahead and did the grounding on. Was that just not general practice years ago? These are OLLLLLD switches. late 70/early 80's when they were probably put in.
Old 12-14-09, 09:47 AM
pcboss's Avatar
Correct, older code did not require switches to be grounded. This has changed and are now required to be grounded.
Old 12-14-09, 09:48 AM
I
Received 43 Votes on 41 Posts
The grounding requirement used to be more lax. Based on current code, a switch in a metal box with metal screws does not require a separate ground wire to the switch. All other situations require a ground wire directly to the switch. I usually add one anyway.
Old 12-14-09, 03:41 PM
as did I...you guys have taught us good habits!!!
See, your wisdom helps!!!Beer 4U2
