Unfinished basement receptacles
Old 12-15-09, 08:26 AM
E
I need to run a few receptacles in my unfinished basement. They will be installed on the bare cinder blocks on the wall. I am running nm cable from the panel to the receptacles in the joist bays.
From what I understand I need to sheath the nm cable with conduit (emt) from just above the bottom of the joists down to the box. I have sheathing clips in the top of the conduit.
Since the conduit and the box will both be flush with the wall I need to deal with the offset from the hole in the box to the conduit. I bought some offset connectors figuring this is what they were meant to be used for, but the offset is way too much for the boxes I have.
What is the best way to handle this? Do I need to make the bends in the conduit manually, or are there offset connectors for this?
Also, is 3/4 in conduit big enough for 10/3 cable for this purpose?
I'm in MN if that matters.
Thanks
Old 12-15-09, 08:32 AM
I
Received 43 Votes on 41 Posts
You should be able to find an offset that is the correct size, or you can make one but a bender is a bit expensive for one small project. If the gap between the conduit and wall is not that big (1/2" or less) you don't really need an offset.
Should be okay.
Curious as to why you have 10/3 for receptacles?
Old 12-15-09, 08:42 AM
E
It's for a dryer.
Thanks for the help.
