adding switch with new track light fixture
Old 12-15-09, 07:42 PM
R
Question adding switch with new track light fixture
Im replacing my old pushbutton switch florescent light fixture in my bathroom with a new 3 light tracklight fixture...I want to add a single pole switch for it... the old fixture was hardwired from a 2 wire and ground that looks like its coming from a receptical close to the old light in the bathroom.. What do I need to do ???
Old 12-15-09, 08:24 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
You will need to run 12-2 or 14-2 Romex to where you want the switch. This is called a switch loop.The white wire of the new Romex should be re-marked in red (or any color but white or green) with tape or felt tip marker on both ends.
At the light:
The white of your original cable goes to the white of the light.
The black of the original cable goes to the black of the new cable.
The red (recolored white) of the new cable goes to the black wire of the light.
At the Switch one wire to each screw.
All grounds tied together and if a metal box a pigtail to the metal box.
12-2=20 amp breaker 14-2=15 amp breaker
Old 12-15-09, 08:56 PM
B
Here is a picture which might help...
http://www.make-my-own-house.com/images/ellightbulb.jpg
White is called "neutral".
Black is called "hot".
Bare or green is called "ground".
I found the above picture/diagram by going to google.com, clicking on "Images" at the top, then searching for the words...
wiring a switch
Old 12-15-09, 09:16 PM
R
diagrams do make it easier to understand,dont they ...Thanks for the tip..
Old 12-15-09, 09:19 PM
R
Does it matter how the Romax is wired on the other end of where the exsisting one was for the old light ???
Old 12-15-09, 09:38 PM
ray2047's Avatar
The picture linked to above is wrong for his situation. It shows power in at the switch. He has power at the light.
This is the correct diagram:
Old 12-15-09, 09:44 PM
ray2047's Avatar
Yes, see my instructions and the diagram in my last post. The other diagram posted earlier is wrong for your situation.
Old 12-15-09, 10:00 PM
R
Its starting to make sense now...Thanks Ray2047...I'm going to research "Switch Loop " a little more online so I can feel a little more comfortable sleeping at night not worrying about the house burning down..
Old 12-16-09, 05:32 AM
where do you find those diagrams
Old 12-16-09, 09:41 AM
ray2047's Avatar
You can just Google them. I just draw them out using Kolour Paint and Gimp. That's why mine are so crude.
