Code for placing electrical wire in attic
Old 12-17-09, 01:15 PM
K
Iím rewiring and re-insulating my attic. From a NEC standpoint, what major codes do I have to follow when placing wires across the attic joists?
Can they be stapled onto the top of the joists with fiberglass insulation covering them? Do I need a conduit?
I have a truss roof. Just making sure I place everything correctly.
Old 12-17-09, 01:20 PM
I
Received 43 Votes on 41 Posts
If the attic is accessible for storage through stairs or a doorway, then all wiring needs to be protected by running alongside the trusses or 2x4 running boards nailed perpendicular on the trusses. If the attic is only accessible by a scuttle hole, then only wiring within 7' of the scuttle needs to be protected. It is generally considered protected if you run it through inaccessible areas like the edge of a hip roof where it would be impossible to walk or crawl.
