Change conduit size mid-stream?
Old 12-18-09, 05:44 AM
B
Received 1 Vote on 1 Post
All,
I am in process of putting a 100 sub panel in my shop. I already have buried and have had inspected a 2" conduit between the shop and the house. Yesterday I bought the #1 conductors to string between the main panel and the subpanel and can now see that a 2" conduit is larger than I need. For ease of running the conduit from where it meets the house to the main panel I would like to run a conduit smaller than 2". Is it OK to reduce the conduit size where it enters the house?
Thanks in advance,
BWSwede
Old 12-20-09, 11:01 AM
chandler's Avatar
Received 4 Votes on 4 Posts
As long as your conduit fill is not exceeded by the conductors you are putting through it. One down side would be future additional upgrades. IMO, I'd run 2" all the way.
Old 12-20-09, 01:24 PM
At this time i cannot give you a reason except it is not a good practice! It would be hard to pull wire through when you hit he reduced pipe.
Old 12-23-09, 03:38 PM
B
Thanks guys. You both state good reasons not to do it. Because of my clearances, I think what I am up against to get a 2 inch conduit up inside the wall to the main box will be more difficult than dealing with a conduit that changes in size.
Thanks again. I appreciate your responses.
BWSwede
Old 12-23-09, 06:06 PM
Tolyn Ironhand's Avatar
Received 90 Votes on 80 Posts
Add a pull box (junction box) in an accessible spot indoors or out. Run the 2" into one side and the smaller size out the other. If the conduits are roughly inline you can fairly easily pull through the box.
Old 12-24-09, 08:11 AM
B
Tolyn,
That is a great idea. I have an LB just at the right location to do something similar.
Thanks,
BWSwede
