Using a 3 way switch in a one way application?
Old 12-21-09, 11:08 AM
I purchased 3 way dimmer switches by accident when I only needed one way dimmers. Is there an easy way to use the 3 way switch in a one way application? Seems like I should be able to just use a jumper wire between the two travellor connections?
Old 12-21-09, 11:27 AM
pcboss's Avatar
Received 85 Votes on 73 Posts
Some dimmers are convertible between single pole and 3 way operation. You really need to check the instructions included with the dimmer.
Old 12-21-09, 09:23 PM
F
What model number dimmer switch you have ?
The reason why I asked due some can able run in single pole mode but some case no it can not.
Merci.
Marc
Old 12-22-09, 05:34 PM
Merci.
Marc
It's a Leviton Maestro. I already checked the instructions and they don't mention a single pole mode. I guess my question is if there is a generic way to make it single pole mode by using a jumper wire and connecting the hot lead to the travellor lead. I believe that should work....
Old 12-22-09, 06:49 PM
C
The generic way is just to cap or ignore one traveller, and connect the other to your load.
Perhaps you mean Lutron Maestro. I think you can ignore the blue screw if that is the case.
Old 12-22-09, 10:14 PM
F
Classicsat is right most case it will ingore extra traveller conductor however as he mention Lutron Masetro if that is correct model then just cap off the bleu conductor and you are good to go.
That should clear up some issue you have there if not let me paste the wiring diagram here.
http://www.lutron.com/CMS400/WorkAre....aspx?id=18045
Just click on that and it will download the details you need to know.
Merci,Marc
Old 12-30-09, 12:40 AM
Sorry, it's a Leviton Vizia Model # VZOOR-1L
There are the following leads on this dimmer:
WH = white hot?
BK = black neutral?
YL/RD = travellor?
There's also another lead that I think is a ground....
So just hook up WH and BK and ignore the travellor? I think my contractor tried that without success...
Old 12-30-09, 05:38 AM
pcboss's Avatar
Black should never be a neutral. Green will always be the ground.
What did the instructions call for connection wise?
Old 12-30-09, 06:02 PM
C
That is not a dimmer. That is a remote for a
Vizia 3-way dimmer or other device.
Old 12-30-09, 07:01 PM
F
I agree with Classicsat this is a remote device not a master dimmer at all so you have to take it back to the store and get the correct model.
Merci,Marc
Old 01-06-10, 01:11 AM
Thanks. I can't return it anymore - I bought it off E-bay and it was advertised as a dimmer which in the fine print actually said 3-way dimmer.....
