Blower Motor
Old 12-22-09, 09:13 AM
Red face Blower Motor
I purchase a used blower motor that I just want to
used as a fan in the garage. But I am not sure on how
to wired it, can you please help!
the motor has five wires one is: black, yellow, red, dark
blue and a green which is the ground wire.
I did find a cust. part no. 207166?
I will be connecting to 110 not sure which two wires to connect to make fan run?
access43
Old 12-22-09, 10:10 AM
ray2047's Avatar
Is there a name plate on the motor? What is the info on it? Is there a connection diagram on either side of a removable plate where the wires come out?
Old 12-22-09, 11:37 AM
Blower Motor
The plate is not easy to read here what i could make out cust. part no. 207166, RPM 107XXXX, MFG NO. J33 8, hz 60,
not sure what this number is K55HXCKP
could this enough to let me know what two wires to connect
to make it work??
Old 12-22-09, 11:47 PM
Unfortunately you are not giving enough information to be able to give you an accurate connection. Your blower motor is multi speed. Black is high speed, red is low speed, blue is usually med or med low and yellow is a speed often medium. Yellow can also be a connection to a capacitor.
At this point we do not even know what voltage the motor is but it is generally pretty common to have a white wire if the motor is 115 volts. You do not mention a white wire.
Old 08-12-12, 10:59 PM
your blower motor
did you ever get it working. If you no longer need it, would you sellit to me for my a/c in my house?
Old 08-13-12, 12:23 AM
The OP hasn't logged in since the end of 2010. He's unlikely to read this.
Old 08-13-12, 05:02 PM
CasualJoe's Avatar
That's right, the last post is over 2 years old. If anyone is interested though, he had an Emerson motor. Since that last post, Emerson sold their motor business to Nidek.
Home
