Adding an outlet from GFI
Old 01-09-10, 12:38 PM
T
My house is 20 years old and I need to add an additional outlet in my bedroom. The easiest place to get power is from the attic above my garage at the garage ceiling outlet. This is part of the GFI circuit.
Does anyone think that would be a code problem to take power off this outlet to add a new outlet into the bedroom?
Thanks
Old 01-09-10, 01:07 PM
Tolyn Ironhand's Avatar
Received 200 Votes on 178 Posts
If you add the outlet in the bedroom it is required to be AFCI protected per 2005 or later code. I can't say for sure if the GFCI and the AFCI will play nice with each other. Other than that I can't think of any other issues.
Old 01-09-10, 01:11 PM
pcboss's Avatar
Received 83 Votes on 71 Posts
AFCIs should also be compatible being fed from from a GFI circuit or vs versa.
Old 01-09-10, 01:35 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Is the receptacle GFCI or is the breaker GFCI. If the breaker is GFCI you may have to switch it to AFCI and change the receptacle in the garage to GFCI.
Old 01-09-10, 02:27 PM
T
The outlet I want to tap into just looks like a normal outlet (ie no reset button). It is on the GFI circuit like the other garage and exterior outlets.
Does the AFCI for bedrooms apply to remodels? IF I have 5 outlets in a room and want to run one more I would have to make it AFCI?
Old 01-09-10, 06:12 PM
pcboss's Avatar
Installation of new wiring should meet the current Code requirements. This would mean that you would now need AFCI protection for the bedroom.
