Reload this Page >
braided metal (Cable) to water main in house (Electrical Panel)???
Old 01-12-10, 06:17 AM
The water meter and main valve to the house pokes up through the slab into the interior laundry room. It looks pretty standard except for a braided metal wire (1/4" dia. perhaps) that connects to the mains piping and back into the wall (external wall, if that matters). I just disappears into the drywall and I havent checked where it goes. DOES ANYONE KNOW WHAT THIS IS? I am covering the exposed piping to keep the cold from effecting the laudry room so much and I want to know what I am covering up!
Old 01-12-10, 06:56 AM
Temporarily Suspended
It's probably the ground to the panel box.
Old 01-12-10, 07:31 AM
Thanks. It could be but it seems like a pretty huge gauge for such a small device. The power lead running out of the house to the front of the garage is pretty narrow gauge. Any other ideas? I should also say it looks like some kind of composite metal like braided aluminum althought that sounds goofy. 1975 era house. It doesnt have enough tension in it to secure it to anything.
Old 01-12-10, 08:33 AM
If it's not securing anything, a ground is my only thought.
Old 01-12-10, 08:37 AM
Received 7 Votes on 7 Posts
Cable
Does the other end of the cable enter your electrical service panel?
Old 01-12-10, 09:26 AM
I dont think so. One end is clamped to the outside of the piping. The other end pokes into the drywall. Its exposed (no jacket) so it just seems funny that it would be ground. Thoughts?
Old 01-12-10, 09:45 AM
A lot of ground wires are bare, and that's sure what this sounds like. A buried metal pipe (your water main) makes an ideal ground.
Old 01-12-10, 10:42 AM
Grounding
I dont think so.
Have you actually looked inside the service panel?
Is this strange cable near the electrical panel?
Electrical system grounding is critical to safety.
Old 01-12-10, 10:53 AM
Cool
water pipe ground, probaly a #4awg does not have to be insulated, and they tarnish over time
Old 01-12-10, 11:02 AM
Talking
Its clamped to the water pipes so if a live wire contacts any pipes in the house the pipes dont become one big electrical conductor, the other end terminates in your panel under a ground bar so as to cause a short and trip the breaker in the event the pipe becomes energized, and is mandatory by code.
Old 01-12-10, 11:35 AM
Thanks RK, WP, Bruce & Pulpo. I'll make sure it's secure.
Old 01-16-10, 07:31 AM
It could be a meter bypass for the electrical ground. A short chunk of copper is sometimes used to connect the house plumbing to the incoming water line, thus "bypassing" the water meter. This insures proper electrical ground while the meter is being changed, or if the meter doesn't provide a proper electrical connection (for example, if teflon tape is used at the meter joints).
Old 01-13-11, 01:27 PM
Update. Remodeling the laundry room now. The cable in question is an aluminum "service entrance" sized braided affair. It is still unhooked. I also noticed a small copper wire existing the meter - this must be the one that Rick noted as a backup in case the meters have to be swapped. I am going to clamp this aluminum cable back to the copper pipes coming out of the ground. Maybe scrub up the points where it connects.
PS - anyone see any issues with this cable being aluminum?
Old 01-13-11, 01:41 PM
pcboss's Avatar
Received 39 Votes on 34 Posts
Could you post a pic of this conductor?
Old 01-13-11, 01:51 PM
It's 6 or 7 wires, 12 to 14 gauge each, twisted as one cable. Aluminum. Sheathing is black but no apparent markings - it is also bare / exposed for 2 feet or so. It comes out of the wall and is clamped directly to the main water entrance pipe (copper) coming into the house. The end of it was also clamped but that was apparently long ago. I will try and get a picture but does this text description help?
Old 01-13-11, 02:25 PM
Received 42 Votes on 40 Posts
It sounds like your grounding electrode conductor, which is required for the safe operation of your home's electrical system. Code requires it to connect to the plumbing service pipe within 5' of entrance to the house. It is also required that the wire jumper over anything non-conductive like a meter or water filtration system. Usually this is done with one long piece of cable clamped to the pipe of both sides of the meter or other break in the plumbing.
Old 01-13-11, 02:29 PM
Ya, it has all those signs. It is indeed clamped below the meter... I just cant for the life of me figure out why someone would have un-clamped it above the meter... that end is just hanging there. Need to tie that on!
Old 01-13-11, 02:35 PM
It happens all the time when a plumber or the city water department swaps out the meter for a new one, replaces the main shutoff valve or similar work.
Most meters and meter yokes are conductive brass, so in practice it makes little difference to have it not connected, but the code does require it just in case.
Old 01-13-11, 07:18 PM
CasualJoe's Avatar
Received 43 Votes on 35 Posts
The NEC in 1975 didn't require that the service grounding conductor run from the panel all the way to where the water service entered the building, but it did require a jumper across the meter. Most likely it's #2 aluminum (assuming you have a 200 amp service) and legal and just a jumper. Your service is likely grounded to a cold water pipe closer to the panel so the jumper is critical and must be attached on both sides of the meter. I'd also be willing to bet you have no ground rod as only one ground was required in 1975.
Old 01-13-11, 08:41 PM
Received 41 Votes on 40 Posts
I also noticed a small copper wire existing the meter...
This one could very possibly be a remote sensor for the water company to read the meter from the outside of the house. If it is, it would be 2-4 small gauge (22-24ga) wires in a single cable. Just be careful to not accidentally cut it.
  #21
Old 01-14-11, 04:22 AM
Thanks guys - cant say that enough. The small one I am sure is a meter feed - I am going to rough in these pipes and cables (will leave them "accessable" just not hanging out like they are now). I always within 2 or 3 feet of a curious 3 year old and I want to be sure the kids are protected. Not sure how I would tell if I have a ground rod or not, or even what the signifcance of this is. By the way, I'd bet the farm that this is the closest connection between the main to the house and the panel given that I know exactly where the wires and pipe run to that area. Thanks again!
