Power to moving door?
Old 01-12-10, 03:34 PM
B
New Member
Building a bookcase door which will have LED strip lights on shelves. How can you run power to a door which opens and closes? What type of connection or harness would be safe and durable?
Old 01-12-10, 03:49 PM
Tolyn Ironhand's Avatar
Received 200 Votes on 178 Posts
Are you planing on using low voltage LED lights? (please say yes.)
Old 01-12-10, 03:50 PM
B
New Member
Yes, LED
Yes, planning on using low voltage LEDs. Just not sure how to power them . . .
Old 01-12-10, 04:54 PM
Powering the lights you will need a transformer (many times call a wall wart) that will change the 120 volt from the wall down to the voltage you need for your lights, likely 12 volts or less. The reason I was hopeing you were going low voltage is because you can pretty much wire it however you like using almost any type of cable/wire. You could even run it inside the frame of the door. Low voltage is just that safe. Of course the two wires/pieces of metal can't touch or the transformer will burn up.
Old 01-12-10, 06:23 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
If it doesn't have to be lit when open a set of contacts on the door jamb and on the hinge edge could be used. Heck, you could use one hinge for positive and one for negative. If the bookcase is wood and the jam wood there should be enough insulation.
Old 01-12-10, 06:46 PM
Z
Received 103 Votes on 96 Posts
I'd recommend 14ga SO wire (black rubber 2 or 3 wire cable). SO is flexible and intended to be moved. Even though it's low voltage, I'd still wire it "traditionally" so you don't have operational problems later down the road.
