30 amp double pole breaker
Old 01-13-10, 09:34 AM
Is it within code to use #10/2 wire and have the white wire as a hot lead as well as the black wire when connecting to the 30 amp breaker?
Old 01-13-10, 09:38 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
Yes, but the white wire needs to be remarked some color other then white or green.
Old 01-13-10, 09:40 AM
pcboss's Avatar
Received 85 Votes on 73 Posts
Yes, this can be done in a cable assembly. The white should be re-identified as a hot conductor by tape or magic marker in a color other than white, green or gray. Normal practice would be red, black or blue.
Old 01-13-10, 09:41 AM
Would it be acceptable to wrap the exposed white wire with black electrical tape?
Old 01-13-10, 09:57 AM
pcboss's Avatar
Yes, just wrap all exposed ends of the conductor.
Old 01-13-10, 10:01 AM
Thank you for your help and quick response
