Wiring around heating ducts
Old 01-15-10, 09:40 AM
What is the best way to get a wire around a heat duct in the basement ceiling. The duct fills out the joist cavity. I plan to drywall the ceiling later
Old 01-15-10, 09:54 AM
I
Received 45 Upvotes on 43 Posts
If it's a hot air duct, you have to go around it, over or under doesn't matter. If it's a cold air return boxed into the joist space, you can go through it perpendicular. Caulk the bore holes after the cable is through.
Old 01-15-10, 11:22 AM
It is a hot air duct
Will the cable get overheated if it touches up against the hot air duct
Old 01-15-10, 12:09 PM
Tolyn Ironhand's Avatar
Received 710 Upvotes on 603 Posts
No, it will not.
Old 01-15-10, 09:46 PM
R
Not an electrician here ,
I read on the Electrical Code Simplified[Ontario]:
''loomex cable to be kept at least 25mmm [1''] away from all heating ducts and hot water pipes, a chunk of building insulation may be placed between the cable and the duct''
Dont know how accuarate this is, I found that this book contains some info not applicable in Ontario .
