Sub Panel Question
Old 01-30-10, 06:19 PM
Sub Panel Question
I just picked up a new air compressor, and so I will need a new 240v outlet. The problem is that my main panel is completey full (and outdated too probably). I really don't want to install an all new main though. So can I run a 240 off of a sub panel? Can I run multiple appliances off of the sub panel. If you look at my main right now, it has a 200 amp main. Then there are 2 50 amps for the range. I figured this would be the best place to bring the sub panel into. The problem is that I would then have to have a place on the sub panel for the range and the compressor. Is this possible? How big of a sub panel do I need?
My current main:
Old 01-30-10, 06:57 PM
pcboss's Avatar
Received 84 Votes on 72 Posts
When installing a subpanel it is best to leave the large draw items like the stove in the main panel and move smaller branch circuits to the subpanel.
The panel feed would be determined by what you need to run off it. I would think a 40 or so would serve your needs well and still have room for expansion.
Your panel is a Pushmatic which is no longer produced but if you search you can get breakers for them at a price premium over current models.
Old 01-30-10, 07:04 PM
So you're saying maybe it would be best to move a few of the smaller circuits over to a sub panel and wire a 240 on the main?
Old 01-30-10, 07:18 PM
pcboss's Avatar
Yes. ..................
