Electrical code
Old 01-31-10, 06:12 PM
Y
Electrical code
Minimum distance an oil burner/furnance needs to be from an electrical breaker panel in the state of MA?
Thanks!
Old 01-31-10, 06:17 PM
pcboss's Avatar
Received 92 Votes on 79 Posts
The NEC minimum workspace requirement for the panel is a 30" width that does not need to be centered on the panel and a 36" depth.
Old 02-01-10, 12:27 PM
TomZ1's Avatar
FYI--The tank must be at least 5-feet from a panelboard per NFPA 31.
Old 02-01-10, 12:46 PM
I
Received 43 Votes on 41 Posts
Some jurisdictions also enforce a minimum height of 24" from the floor for receptacles and switches in rooms where petroleum products are stored.
Old 02-03-10, 06:59 PM
C
yea just make sure that you have 30" of clearance for the panel and the door on the panel can open the full 90 degrees and dont worry about headroom because anything under 200a you can have a headroom of less than 6 1/2 feet as per the NEC 2008, i just did a job in jamaica plain and the inspector cleared that with me right next to a oil tank, so your good.
Old 02-03-10, 07:19 PM
pcboss's Avatar
The NEC certainly does not agree with the headroom requirements posted above. Article 110.26(E) requires a minimum of 6'-6", regardless of ampacity. Article 110.26(F)(1) also requires dedicated work space to extend from the floor to a minimum of 6' above the equipment or to the ceiling, whichever is lower.
Old 02-03-10, 07:45 PM
C
did you miss the exception?
110.26 (E) Exception: In existing dwelling units, service equiptment or panelboards that do not exceed 200 amperes shall be permitted in spaces where the headroom is les than 6 1/2ft.
thats verbatim right out of the NEC 2008 which mass goes by
Old 02-03-10, 08:30 PM
pcboss's Avatar
Yes I did miss the exception. Thank you for the correction.
