replacing outlets
replacing outlets
What is the proper way to replace a two prong outlet with a three if you have no ground to the box
Received 38 Upvotes
Install a GFCI receptacle and be sure to place the included sticker on the face of the receptacle that states: No Equipment Ground.
This improves personnel safety but does NOT give a ground reference which is necessary for surge arrestors or some electronic equipment.
