plz help
Old 02-08-10, 03:43 AM
plz help
i want to ask how can i nknow the value of the diode ziner which is colored orange and the other one which is colored black or almost gry , bcuz i want 2 replace a burnt ona with another but it doesnt have the same num. on it
plz if any 1 has an idea say it
and thanx 4 help
Old 02-08-10, 05:08 AM
Type the number of the original zener diode into a search engine along with the word "datasheet".
Old 02-11-10, 03:24 PM
thanx i will try, even thoudh i used to write the num. but it didnt work , i need the voltage and the watt
but i will try ur 2nd option
Old 02-11-10, 03:56 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Toookyo it will be easier to get help if you use a proper subject. For example you could have titled you post: "Need Data On Diode".
It will also help if you avoid "IM speak" and do a spell check before posting. I normally paste my post into a word processor before posting and use it to spell check since the forum doesn't have a spell check. Also your shift key doesn't seem to be working.
Old 02-11-10, 07:44 PM
what numbers do you see on the old and the new??
Old 02-12-10, 05:57 AM
ray2047's Avatar
Toooky soorry for my previous post. I did not know you were not from the USA.
