Can Light in Bathroom shower stall
Old 02-12-10, 01:19 PM
Redoing shower stall and thinking of putting in light over the top of the shower for effect and function. Easy enought to come into existing light over sink and run romex over wall the shower. Do I need a special can fixture or anythig "rated" for shower use?
Old 02-12-10, 01:51 PM
W
Received 1 Vote on 1 Post
Just trims rated for wet locations, for example Recessed Lighting, Shower - ShopBathroomLighting.com
I
Received 43 Votes on 41 Posts
Any can is acceptable as long as you use a "shower trim" which matches that can and the correct bulb type for that shower trim. They are usually more restrictive like 40W max bulb.
Old 02-12-10, 02:00 PM
W
Sorry I said wet location, depending on whether or not it's subject to shower spray will determine the wet or damp location.
Old 02-12-10, 02:14 PM
F
I understand some concealed type down-lights are special designed to be used in shower stall.
Old 02-12-10, 06:49 PM
E
Any Can
Any Hi Hat type fixture will do, just needs to have a shower trim installed..
Old 02-12-10, 09:41 PM
CasualJoe's Avatar
Received 83 Votes on 73 Posts
Halo makes a nice shower light trim.
