underground 1/2" PVC splice
Received 0 Votes
Hi,
I would like to cut an existing 1/2" PVC run for some driveway lights to make digging a trench 90* to the PVC easier. I plan on installing 2 splice boxes on each side of the trench to connect the light wires back together once the trench is finished. What would be the correct 1/2" conduit box that can be buried underground afterwards? Or would I have to run a new section of PVC and wire between the lights where the trench will be dug?
Thanks
EDIT: I want to use a regular conduit body with a seal, but I am not sure if they are approved for underground buried connections.
Thanks
Hi,
Thanks
Thanks
Best thing to do is remove the wire, cut the pipe and install 2 - 90s (one in one out) that will come up into the bottom of the lights. You can also add 2 more 90s to place the light in a location other then where the pipe is. Just make sure to have no more than 4 - 90 degree bends.
