Wiring Requirement for Post Lamp
Old 03-11-10, 03:19 PM
n1ml's Avatar
I am adding a post lamp about 12' from the house along the front walkway. There is an outlet box on the wall that has a GFI in it. It is also the outlet box that feeds another post lamp far down the driveway. My plan is to tap into the same feed as goes out to the far away post lamp. The wire is 12AWG UF and goes thru a plastic pipe to about 16" below ground. The digging is real difficult in the area due to trees and roots over the 12'. I could use 12 AWG UF but the digging down to 18" would be difficult. I would like to use gray pvc at 6" below grade. Can I use THHN, 12 AWG, blk/wht/green in the conduit?
Thanks
Old 03-11-10, 03:52 PM
pcboss's Avatar
Received 78 Votes on 66 Posts
The minimum burial depth is 12" if the run is protected by GFI protection, unless under concrete.
Without GFI protection the depth is 18" minimum to the top of the cable or conduit.
Old 03-11-10, 03:59 PM
n1ml's Avatar
The 12" sounds better already. I guess i was mistaken about the 6" depth in conduit. Sounds like the best idea is to use the load feed from the GFI directly to the light post. There will be a socket controller that allows the light to come on at dust and stay on eitehr 4, 8 or 12 hours.
Old 03-11-10, 04:12 PM
pcboss's Avatar
If rigid or IMC conduit is used the depth can be 6".
Old 03-11-10, 05:21 PM
n1ml's Avatar
If I use rigid or IMC, what kind of wire conductors are required?
Old 03-11-10, 06:57 PM
pcboss's Avatar
You would still use THWN.
