Charger
Received 0 Votes
Charger
Hello,
I have a small Bosch IXO screwdriver. I tried to charge it a few times and it seemed battery was remain empty.
I checked the charger, mainly the output voltage on the pins, and it showed 11.5v. On the back of the charger it says the output should be 7.5v. Clearly a big difference.
Hence my questions ...
1. Is it really that the charger outputs too much volts? I was thinking that maybe the reading is biased because I didn't have the IXO screwdriver connected.
2. If it is too high, what are the chances the lithium batter is dead already?
Thanks,
Ronen
Thanks,
Ronen
Lithium battery chargers also have some smarts in them to charge the battery safely. Measuring the voltage doesn't take into account the feedback system the charger has.
Received 0 Votes
The charger itself looks fairly plain. Nothing but a transformer and a bridge.
It seems like the "smarts" is in the screwdriver itself (opened it up yesterday and there was definitely more than just a battery and a motor there).
I noticed that when I place the screwdriver on the charger the charging led lights up very faintly and then diminish. Any idea how I can find what the problem is?
