Wire size for electric stove???
Old 03-23-10, 06:02 PM
D
Want to wire up new electric stove.Does it matter if we use a 3 or 4 wire plug?We have a 3 wire plug now that we purchased and was later told that we were suppose to use 8/3wire.We need a 4 wire plug for this don't we???? Please help! Thanks!
Old 03-23-10, 06:19 PM
chandler's Avatar
Yep. Modern code calls for a 4 wire set up, and generally 8/3 with ground is used for this application. If the stove has a 3 wire plug, replace the pigtail with a 4 wire and run 4 wire cable to a new 4 wire receptacle.
Old 03-23-10, 06:39 PM
T
What breaker should be used with 8/3 w/g?
Old 03-23-10, 07:06 PM
CasualJoe's Avatar
I'd use a 2 pole 40 amp breaker.
Old 03-24-10, 04:51 AM
chandler's Avatar
CJ is right. Check the amperage requirements of the stove. Some require a 50 amp circuit, which would up the ante to 6-3.
