Is Romex OK in Apartment building in MD?
Old 03-23-10, 06:12 PM
bish80's Avatar
I was installing one of those monster HDTV's in a friends house in Maryland. I cut the wall open to install cross braces. From inside the wall I could see the recepticle box. It was plastic with romex running into it. This is a 10 story building. I have been told that anything over 4 stories requires bx. Does anybody have an idea what the rule is with regards to bx vs romex in Maryland?
Thanks
Scott
Old 03-24-10, 09:04 AM
pcboss's Avatar
Received 40 Votes on 35 Posts
If the building is of Type III, IV or V construction NM cable can be used.
Old 03-24-10, 08:51 PM
bish80's Avatar
Thanks for the info
Thanks for the info. I'm going to bet the electrician a buck on this.
Old 03-25-10, 08:20 AM
Tolyn Ironhand's Avatar
Received 73 Votes on 65 Posts
This was changed in the 2002 code. (IIRC I don't have my 1999 code book handy) PCboss is correct.
Old 03-27-10, 02:23 AM
Yep Tolyn is correct it was changed in 2002 NEC code however some local code may still restrict it so check it out for latest info.
Merci,Marc
Old 03-29-10, 03:32 PM
bish80's Avatar
Thank you
Thanks Gentlemen for the good info.
Scott
