Service Drop wire size from weatherhead
Old 03-26-10, 09:48 AM
I did a search but did not see this answered anywhere.
I am in the process of preparing to replace my main panel and sub panel with a new single panel 40 position unit. I was originally only planning on installing 125 amp service to alleviate having to replace the service wire from the pole.
After calling the local utility and having them come out and look at my overhead lines, they have rated the 1/0 triplex wire to 200amps (how, I do not know). Since discovering this, I am just going to go ahead an and install a 200 amp, 40 position panel as they can be had for ~$125
In doing this, I will need to install a new conduit from the panel, new meter base and new weather head. My question is what size wire should I be running from the existing overhead lines to the meter? And from the meter to the 200 amp main. I did not think the 1/0 would be big enough.
I will not personally be disconnecting or reconnecting to the mains.
Thanks.
Old 03-26-10, 10:06 AM
pcboss's Avatar
Received 35 Votes on 30 Posts
The correct sizes would be 4/0 AL or 2/0 copper. These will need to be marked "Sunlight Resistant".
Old 03-26-10, 10:35 AM
Thanks.
The PoCo has there own rules governing the wire size from the pole to the house. Most house that get upgraded to 200 amp services never have there service drops changed. Most houses still and will always have orginal service drops.
Received 42 Votes on 40 Posts
Wires hanging in free air are naturally convection cooled allowing them to safely carry significantly more current than their conduit-enclosed counterparts.
#2/0 copper or #4/0 aluminum. THWN-2 with UV resistance or XHHW are common types of wire you can use for this.
Old 03-26-10, 06:47 PM
Thanks for the responses. I think I will go copper so I can use a smaller conduit.
Old 03-27-10, 01:00 AM
You will need 2 inch conduit for this one due the conductor size I know you say 70mm˛ { 2/0 AWG } copper and the other gotcha is if you going with telescope mode { go thru above the roof line } majorty of POCO { power company } will required 2 inch ridge steel conduit and may have to back guyed due some span will need to support the POCO conductors.
Merci,Marc
Old 03-27-10, 07:59 AM
You could put (3) #2/0 in a 1-1/2" conduit, but you will have a better day if you use 2", especially if there are any LB fittings.
Old 03-27-10, 08:07 AM
CasualJoe's Avatar
Received 40 Votes on 32 Posts
Some overhead meter sockets come with a 2" hub factory installed on top of the socket. I have always considered 2" conduit a standard on a 200 amp service.
Old 03-27-10, 05:55 PM
Most if not all 200 amp meter pans come with the hub as well.
Old 03-27-10, 06:27 PM
badeyeben's Avatar
Every power company I have worked with will supply a spec sheet that details what size wire you need. Also grounding details and ground rod details such as how deep it needs to be below ground and how far away from the footings. Also will specify what size conduit and how many clamps it needs and how far apart the clamps go. Remember the power company has the last say on if they connect to your setup or not.
Old 03-27-10, 06:43 PM
Thats not entirely true. At least in NJ its not. In order for a cut in card to be issued for a service connection, it needs to be locally inspected first. NEC regulates grounding and wire sizes etc... If it is not up to code then it wont pass local inspection and it will never even get to the power company for approval. Usually, and i mean 100 % of the time, if it passes local inspection, it passes PoCo inspection.
Old 03-27-10, 07:57 PM
CasualJoe's Avatar
I have also seen a lot of those spec sheets from the power companies and have found they always conform the NEC and local amendments except that the power company has the right to specify the meter socket to be used, location of the service and sometimes the diameter of the rigid steel conduit mast in reference to the height above the roof. It's hard to imagine, but I have seen quite a few 2" rigid steel conduit masts that had been bent by the pull of the service drop.
Old 03-27-10, 09:18 PM
CJ.,
Ya are not alone on this one I have see it even with big 4 inch ridge conduit for riser it do bent from weight of ice plus few trucks snag it.
In my area in Wisconsin the 2 inch ridge is the smallest they will allow for perescope { thru the roof } set up on single phase but for three phase service it will be minuim of 3 inches ridge.
And all prescope must have backguyed attached to the structure member not the roof sheeting alone.
In France it automatic backguyed with ridge conduits regaurdless of size.
Merci,Marc
Old 03-30-10, 10:24 PM
A couple of things. The power company was quite specific that the do not recommend and power drop requirements for residential installations. It is completely up to the local requirements. My city inspector only said it must conform to NEC specs.
As for the mast, it will be attached to the rear of a 2 story home and the overhead wire will be attached to a tie off insulator bolted into the second story rim joist. There will be no weight on the mast itself.
Thanks again.
Oh and I stopped in to the local Home Depot for a couple of other items and the person in the electrical department (said he was a retired electrician, but you never know) said that I could use THHN for the wire. I thought I needed to use sunlight resistant and THHN isn't, is it?
Old 03-31-10, 09:11 AM
In that case, the mast can be regular PVC conduit. It should be supported with a pipe hanger or strap every 3' up the side of the house.
Some is, some isn't. It's usually printed on the wire if it's sunlight resistant. You also could consult the manufacturer's spec sheet which are often online. Here's Cerrowire brand:
THHN/THWN-2
They state that their black THHN/THWN-2 is sunlight resistant. The surface print on the wire also includes "SUNLIGHT RESISTANT" according to the spec.
