Bathroom GFCI 15 or 20amp?
Old 04-01-10, 11:48 AM
Friends house is 100 years old. Says its legal to just switch out the old outlet and put in a 15 amp gfci. I thought all bathroom outlets must be 20 amp Gfci protected. So who is right?
Old 04-01-10, 12:42 PM
pcboss's Avatar
Received 40 Votes on 35 Posts
The bathroom duplex receptacle does not need to have the 20 amp slot configuration. The circuit should be a 20 amp to satisfy recent NEC codes.
Old 04-01-10, 12:44 PM
It is acceptable to replace any existing standard receptacle with a GFI-type using the existing wiring . The requirement for a 20 amp Branch Circuit to supply bathroom GFI receptacles applies only when the wiring in the B-R is a new installation.
Old 04-01-10, 12:45 PM
Received 42 Votes on 40 Posts
If the wiring is left as-is you can stick with the existing grandfathered 15A. If this is a renovation, then it must be upgraded to a 20A circuit according to modern code.
Old 04-01-10, 03:47 PM
Good looking out my friends. Thanks
Old 04-01-10, 04:54 PM
SilverTattoo's Avatar
If you are expecting a inspector to show up, you might want to label it "No Equipment Ground." NEC 406.4(3)(B)
Assuming that its 12/2 or 14/2 non ground wire.. If the 100 year old house has had a service upgrade and the wire has a ground all is good. Then again if its 100 years old and all original Im not sure it even has to have a GFCI period do it? Its still grandfathered in still... Although its a good idea to have on.Beer 4U2
Also NEC 210.11(3)
It basically says it should be a 20amp circuit but it does list exceptions.. NEC 210.23(A)(1) and (A)(2) which would allow a 15amp receptacle from what I gather in a single bathroom on a 20amp circuit which is by code. It says nothing about a 20amp receptacle, just the circuit.
