need help wiring switch
Old 04-04-10, 12:30 PM
I got a timer switch for my coach lights. The switch has a r/b/w/g wires. Currently there is a single pole switch wired to the lights.
How do I hook this think up?
Old 04-04-10, 12:50 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Do you have a single 2-conductor cable in the box? The colors you give for the timer seem to indicate it needs a neutral. What does the instructions say that came with it? If you only have a black and white wire plus ground and the switch needs a neutral it will not work. You can either run new wiring or get a switch that does not require a neutral.
Old 04-04-10, 12:57 PM
In the jbox there are 4 cables coming in. (there is also a 3 way wired in this location) So there are big bundle of White, Bundle of blacks, bundle of grounds, and one red wire that is running into the 3 way switch.
Old 04-04-10, 01:15 PM
ray2047's Avatar
Confirm by reading the instructions that white is neutral.
With breaker on and switch off using a multimeter or test light or a solenoid tester but NOT a non-contact tester carefully measure between ground an each screw of the existing switch. The screw that shows 120v is line (power in). The other is load
Follow the timers instructions. Usually "Line" goes to the black. Red to the "load". White to the bundle of neutrals. Green to the bundle of ground wires.
Note above assumes neutral in switch box based on description. You would need to isolate eac 2-conductor cableand check one was power in to be sure but the procdure above should work with out doing that. If there are two bundles of white wires stop and post back.
