AC thermostat
Old 04-12-10, 05:52 AM
AC thermostat
I have a tenant that called and said that his AC thermostat keeps resetting his settings. When the unit finishes its cycle, it will reset the temperature settings to the default setting.
Any ideas as to what is causing this? How can I fix it?
Old 04-12-10, 06:14 AM
braether3's Avatar
low battery.
message too short......................................blah
Old 04-12-10, 06:21 AM
hmm
Thermostats have bateries?
Old 04-12-10, 06:38 AM
RHefferan's Avatar
Some digital ones do, yes.
Old 04-12-10, 07:10 AM
I would read over the instructions again and make sure he or she is setting it correct. Also, replace the batteries with new ones that you know they work.
Jim
Old 04-14-10, 05:37 PM
CasualJoe's Avatar
Received 22 Votes on 17 Posts
What is the manufacturer's name and model number of the thermostat. Some digital setback thermostats (inexpensive ones) operate from battery power and others (the better ones) only use a battery to hold the program in the event of a power outage. Need more info.
Old 04-14-10, 07:36 PM
braether3's Avatar
Just about every modern digital upgrade thermostat uses battery's the older ones that were installed when the furnace was installed have a 24volt common but many times thats not available in when upgrading from mercury bulb to digital.
give us the name and model if possible or the Age of the unit.
Old 04-15-10, 04:37 AM
Received 1 Vote on 1 Post
Also, if I may add, programmable t-stats have a run and hold mode. If you set the temp and it's in the "run" mode then, the next time in the program comes through, it will revert back to that setting.
If you don't want to program the thermostat, then have the tenant hit the "hold" function, then it will maintain that set temp.
Old 04-15-10, 07:13 AM
Right on. This is a great feature for people who want a burst of heat or AC now but want the system to go back to normal after a while.
On the other hand, it's the automated, passive-aggressive version of the scenario outlined in this article:
Marital Frustrations Channeled Through Thermostat | The Onion - America's Finest News Source
