what to used 50 amp 0r 60 amp
Old 04-19-10, 07:40 AM
pgtek's Avatar
Received 1 Vote on 1 Post
Hi Alll
i live in Canada and have a new tankless water heater
it recommend 54 amp breaker
I can get a 50 amp or 60 amp
if 50 amp is ok i will get it and run # 8 wire and have a cutoff switch for 50 amp
or
if 60 amp is ok i will get it and run #6 wire and have a 60 amp cutoff also
so what should i used
Thanks
Old 04-19-10, 08:29 AM
pcboss's Avatar
Received 103 Votes on 89 Posts
Does it say a circuit ampacity of 54 amps? You will not find a circuit breaker in 54 amps.
Old 04-19-10, 09:35 AM
P
The design of this appliance Branch Circuit , i.e. , the ampacity of the conductors and the rating of the circuit-breaker, is predicated on the connected load as expressed in kilowatts and voltage.
We need to know the exact rating in both volts and watts / kilowatts.
