Removing intercom/radio-questions
My 1970 house has a Miami-Carey radio/intercom that no longer works. I am going to remove the radio/head unit from the kitchen wall. I pulled it out to look at it, expecting to find a 110v connection. Instead I saw pairs of very thin wires like a telephone or a door bell use. I assume there's a transformer somewhere but I don't see it in the basement and I'll probably never find it in the attic space if it's under the insulation.
Can I just cut the wires and tape the ends without being in violation of any electrical codes or creating a fire hazard?
The best solution is to remove the wire completely. I would only abandon it in the wall as a last resort, and only then if I was absolutely certain it was cut as close as possible to the entry point of the room where your panel is, so that it may never be reconnected again.
Yes I have a volt meter. I was planning to get some readings. The connections between the radio and the power wires are taped (I assume soldered but didn't remove the tape yet).
If the power source is 12v-24v and my guess is it is then you have a transformer somewhere. By killing 15a and 20a 120v breakers one at a time you should be able to determine which circuit the transformer is on. When you find the magic breaker see what else is dead. That should give you an idea where to look.
Turns out the transformer is right on the service panel. I thought that was for something else. So the correct approach would be to remove the connections at the transformer and remove the wires also, or at least clip them so they can't be reconnected, right?
Of course if you don't have a door chime and want one the wiring and maybe the transformer could be re-purposed for a door chime.
