8/3 or 6/ wire???
Old 05-11-10, 12:15 PM
D
8/3 or 6/ wire???
Was told i could use 8/3 wire for electric stove with 50 AMP breaker.After purchasing wire someone told me i have to use 6/3 wire. Can anyone help?? Thanks!
Old 05-11-10, 12:31 PM
I
Received 45 Votes on 43 Posts
A standard freestanding electric range can be wired with #8-3g cable and a 40A breaker. Occasionally high-end ranges require a 50A breaker (as specified by the manufacturer instructions) and will need to be powered with #6-3g cable.
Old 05-11-10, 12:52 PM
D
Will it hurt to use the 8/3 wire with the 50 amp breaker?
Old 05-11-10, 02:23 PM
RHefferan's Avatar
Yes. #8 is only rated for a 40A circuit except under very specific exceptions. You must use at least a #6 for a 50A circuit.
And that's providing the wire material is copper. If it's aluminum, you need a #4 or larger.
Old 05-11-10, 02:35 PM
I
#8 cable should not be used with a breaker greater than 40A.
Old 05-11-10, 06:01 PM
Tolyn Ironhand's Avatar
Received 595 Votes on 511 Posts
Just to throw a little monkey wrench into the whole mix, you may use a 50 amp breaker with #8 wire ONLY IF that wire is THHN (or equivalent) and ONLY IF it is individual conductors are in conduit. With cable you may only fuse it at a max of 40 amps.
